Yes No
Ads
Tom's Hardware > Forum > Windows 7 > Drivers > Atheros L1 Driver Problem
Forum Windows 7 : Drivers Atheros L1 Driver Problem
Howdy,
I have a small problem with my W7 drivers for the Atheros L1 network card (ASUS P5KLP motherboard).
After I woke up my internet connection wouldn't start anymore and I troubleshooted with the Windows Troubleshoot program, and it pretty much ended saying that the driver was broken, however the only way to fix it was with a system restore or a driver rollback (which I can't do because Windows doesn't allow me to)
Anyways, I did a system restore, it did nothing, so I procceeded to get the W7 drivers for the network card, but on install it said that it couldn't find any Atheros L1 network card currently on my computer, therefore could not install, which resulted in 1 hour of looking around for an answer both on other forums and checking the system, but didn't really find anything.
Thanks.
Message edited by The_Prophecy on 12-26-2009 at 09:31:03 PM
Reply to Syal
You mean ASUS P5KPL? [not P5KLP] Whats the other numbers after it?
Theres are four different models of that board.
Reply to ibnsina
Find the Atheros LAN adapter in your device manager, uninstall the driver, and check the checkbox labeled "Delete the driver software for this device". Then right click anywhere in the device manager window and click "Scan for hardware changes". This will force 7 to re-detect the device and load the generic driver again.
------------------------------ Please give credit where credit is due! If you think this post was the most helpful, please remember to mark it as the best answer!
Reply to The_Prophecy
I've had problems with the default Win7 driver for this mobo.
Try the Attansic driver, it works fine for me, whereas the default Win7 driver provoked BSODs.
Provider: Attansic
Version: 2.0.6000.0
Date: 15/3/2007
You should be able to download this directly from Asus.
Reply to arkus
Man, these atheros lan cards suck when used with W7. I had many problems with it on W7 RC build 7100 (which I am still using). The net would disconnect, wont connect back etc. etc. Solution: Simple. I bought a cheap PCI realtek lan card and all my problems went away. I am not sure if the solution is available now or not, but you might wanna try using a discrete LAN card having realtek chipset.
------------------------------ AMD Phenom II 720BE, ASUS M4A78T-E, 4GB Transcend DDR3 1333MHZ, Powercolor 4870 1GB DDR5, Corsair 750TX, WD 1TB Green, Maxtor Basics 500GB, Logitech G9x, Wolfking Warrior keyboard, Samsung 2233SW, CM Elite 33x, XBOX 360 Controller for Windows
iPOD Nanoch
Reply to hellraiser06
Thanks to mpowrie:
I also got this problem: When transfering large amounts of data over the network the network card would disconnect, requiring a "disable/enable" to fix.
I am running Windows 7 64 bit RTM and the latest Atheros driver (2.4.7.27).
To resolve, I went into the driver properties, clicked Advanced / Task Offload, and I turned this feature off.
Now, the driver works fine for me
link: http://www.sevenforums.com/network [...] x64-2.html
Reply to NinjaTic07
Sorry about that replying to old post, but I just love answers like this:
Quote :
So, what is a point to post questions like this? If NinjaTic07 give you specific number after P5KPL then you will know what is wrong with Atheros lan chip?
Thanx god other users can be more smart and don't post useless questions instead of says "i don't know".
In my case Atheros was always works bad. In one computer I even has conflict with router (but that's drivers fault). Best drivers I was using for XP some days Attansic drivers (Attansic is pre-Atheros) then new ones but disconnectings, enable/disable thing to resolve, repair etc. is a typical for this chip. I will go to shop and buy REAL lan card I think for resolve all my problems. And that's my advice to you.
Reply to Anonymous
NinjaTic07 wrote :
Thanks to mpowrie:
when i check my speed upload conection disconect or when i want to upload a large file
excelent solution !!!!!!! i work for this ******* problem months
the disable task offload off resolve my problem !
thank you a lot !
:bounce:
Reply to javik_77
There are 1849 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
How to unlock a toshiba laptop bios password
By ebola28, 11 hours ago:
call toshiba, verify you are the owner, and toshiba can reset it for you
Best offers
Top experts
