Archived from groups: alt.games.unreal.tournament (
More info?)
"bob" <nospam@nospam.com> Blessed us with news:2msicfFq212vU1@uni-
berlin.de:
> when i try reducing the speed of the double click to perform a
> dodge i seem to end up being unable to do a dodge at all and
> have to reset the settings to the default to fix it. anyone
> else find this?
I try to keep my dodge setting around 0.5. If I set it too short
I can not dodge at all and if I set it too long I will end up
leaping off of tall clifs and buildings while trying to sneak up
on the edge of it. Very annoying!
I have since learned to
use the crouch key to walk to the very edge of a structure that
I'm standing on top of if I don't want to go hurtling off of it.
If you press and hold the crouch key you can walk to the edge of
something without falling off of it.
J
"Best?? Only a fool will assume they're the best."
Mr.K
For questions you may have concerning UT, UT2003, or UT2004.
http://www.unrealtower.org/faq
