Hi
i just bought a new PC.
i'm trying for 2 days now to install windows but it's not stable.
first i installed win7 64bit. it was slow. & when i installed the ATI driver after reboot the system was all blue screens. over & over again.
so i installed vista. vista32 for starters (my cpu is 64).
it was more stable. but still bluescreens here & there.
so i went to the bios & disabled the new intel turbo option & it was stable. i now could install games & play!
so after an hour i quited to windows & ran the computer rating app that vista has to see how powerfull my system is. but after that ... i got reset.
& every time i went to windows after 20-30 sec the system auto rest itself...
i'm trying now to install XP 32bit.
just to see if it will be stable.
but i really don't know what to do.
is my bios settings are wrong?
the final thing is of course to be able to install win7 64bit.
my sys:
MB: GA-X58A-UD5 (rev. 1.0)
core i7 930 2.8Mhz 8mb cache
12Gb DDR3 1333MHZ PVT36G1333LLK
asus radeon hd 5750 1GB
hdd WD1002FAEX 1TB
links:
http://www.patriotmemory.com/products/detailp.jsp?prodline=5&catid=23&prodgroupid=111&id=759&type=1
http://www.gigabyte.com/support-downloads/download-center.aspx?kw=GA-X58A-UD5
http://support.asus.com/download/download.aspx?SLanguage=en-us
http://wdc.custhelp.com/cgi-bin/wdc.cfg/php/enduser/std_adp.php?p_faqid=5387&p_created=&p_cats=185&p_cv=1.185&p_pv=2.279&p_prods=227%2C279
help!!!
my sys:
hdd WD1002FAEX 1TB
links:
help!!!
