Preferred Wireless Network Problems
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
Hi all,
I am using XP SP2 and I have a Linksys access point running wpa-psk and not
broadcasting the SSIS; however, my neighbor has his network in the default
(unsecured) Linksys configuration and my laptop keeps connecting to his
network when I am upstairs, and does not connect to his network when I am
downstairs (closer to my AP).
I dual boot with 2003 SP1 server, and it connects properly to my AP every
time, and has never accidentally connected to my neighbor's network, unlike
XP.
Is there a way I can force XP to connect only to my network and refuse to
connect to the unsecured network? I have my network under the preferred
networks, and I have my firewall on both OS's.
Thanks for any advice.
MCSE: Security, CCNA, A+, Network +, Security+
Chck if your neighbour's network is listed in the Properties of the
WLAN connection > Wireless Networks. If so, open its Properties and
disable the connection here.
(tm)
Thank you for the response: The neighbirs network has been in my wireless
properties, and I have unchecked the box to connect when this network is in
range.
Thank you for the suggestion, and so far so good.
Take care,
> (tm)
You are welcome.
(tm)
Ask the community
