[System] Asus motherboard P7H55-M PRO w/ i5 processor
[Audio] Onboard 8 channel High Def Audio Codec
Background is this; I need to record two separate inputs, Line In and the Mic. The Realtek HD Audio Manager allows you 3 choices of:
1) Line in
2) Mic
or 3)Stereo mix (this is both inputs mixed together)
This is a one choice wonder. When I go to the audio programs I use for recording, I only see the "Realtek HD Audio Input" for a choice. I do not get to choose, line in or mic. I need to keep the channels separate.
I have been looking everywhere for the answer and I'm ready to throw a rock at my computer. Is there additional software that I can replace the Realtek stuff with? What’s the Answer?
Thank you.
1) Line in
2) Mic
Thank you.
