Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Motherboards > Dual Ethernet Port on my motherboard - Load Balancer?
Forum Motherboards & Memory : Motherboards Dual Ethernet Port on my motherboard - Load Balancer?
My mobo is X48 DQ6
I have two different adsl lines(two modems). Can i connect these two to my motherboard. Will it double up my internet speed?
In short, will the dual Ethernet port on my mother serve as a load balancer?
Thanks guys.
Reply to qiyi
Yes, you can connect both ethernet ports and they will speed up your internet access.
No, it will not double your speed; at least that is my experience with a dual ethernet setup.
Internet access speed is dependent on several things: the number of computers making requests on your local LAN (if you have cable or FIOS access), the sever speed(s), packet arbitration, etc. By making simultaneous dual requests the servers recognize it as a single request (otherwise you would be getting double data downloads for each request) and will send the data to the fastest receiver. You will have the advantage of having two places in line, but the limitation is your request can only be filed once. So you will have increased speed, but not double speed.
To monitor your internet speed I suggest speedtest.net.
Message quoted 1 times
Message edited by Chesteracorgi on 05-25-2011 at 04:27:18 PM
Reply to Chesteracorgi
Good to know it'll increase the speed. Got to try it out and let u guys know later.
Reply to qiyi
There are 1815 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Memory for GIGABYTE GA-G41MT-S2P
By fantastik250, 5 hours ago:
Take a look at this and see if you like it. http://www.newegg.com/Product/Prod [...]...
Best offers
Top experts
