Uninstall Arctic Cooling Freezer 7 Pro Rev2
Easy to fit BUT how to uninstall? The old spring loading type of fitting had a twist to release type mechanism but this appears as a straight pull out - but it doesn't want to come. Anybody done this?
5 answers Last reply
More about uninstall arctic cooling freezer rev2
  1. This one is the same , needs to be in unlock position, check booklet came with item or find one on the web...:)
  2. It's not twist, there's no booklet on the web, and the booklet included doesn't include removal instructions.
    Anyone else?
    Anyone else?
    If it's these you have to pull them out.
    http://www.arctic.ac/en/p/cooling/spare-parts/358/pushpins-new-cpu-coolers.html
    If they won''t pull out easy you'll have to access the back of your board and push them out.
  4. Yeah that's it. Thanks I got them after getting some pliers and squeezing and pulling hard.
  5. Old thread but it's the first result on google so here goes:
    Remove heatsink using the 2 screws. Pinch and pull the black bits out of the beige bits.
    wiggle the remaining beige pegs diagonally towards and away from the cpu and pull.
    Done.
Cooling Arctic Components
