i have a sabertooth p67 and the temps go really high very fast - is it best to use the stock cooler instaid of A50 cos of using a down looking fan so it will go throw the thermal armor ?
What is overheating? The CPU or the mobo? If it is the CPU then do as Uberales suggests. If it is the mobo you may need to switch to a downdraft cooler.
