Solved
Cooler Master V6GT cooler fit into HAF 922 casing?
  • New Build
  • Cooler Master
  • Cooling
  • Systems
Last response: in Systems
July 31, 2010 10:48:07 AM
Hi, i am kinda new to building a system. I trying to build a new system and i just bought a cooler master V6GT cpu cooler, and thinking of getting HAF922 casing. But, the V6GT specs states that its height is 164mm, while the HAF922 spec was saying that it can fit in 160mm tall CPU cooler. From the specs stated, i am worried about fitting the V6GT into HAF922. So, i am wondering if anyone have tried these setup? Might consider other casing if V6GT can't fit in, probably Haf932, but don't really like the casing to be too big... Thanks in advance for any help and information. :)
More about : cooler master v6gt cooler fit haf 922 casing
Best solution
July 31, 2010 1:14:17 PM
yes it will fit nicely in the haf 922
the haf can take any cooler in the world even the biggest (cm v10 and nactua nh-d14)
July 31, 2010 3:34:37 PM
Thanks a lot mrhoshos96! that clear my doubt of having a nice casing haf922. =)
m
l
August 2, 2010 1:41:04 AM
Best answer selected by ZaiZai2k.
m
l
August 2, 2010 1:42:43 AM
u are welcome
m
l
