Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Other Components > Magnum audio cinema surround sound series
Forum CPU & Components : Other Components Magnum audio cinema surround sound series
Does anybody know anything about the magnum audio cimema surround sound series. Maybe the high/def 5.1 m-230?
Reply to lawrence46
is a scam :) , or allmost . i tried one for a friend and it does'n't worth more then 50$ (maybe not even ,but my friend paid 200:P) . is ,,home-made''. on low volume is ok ( just ok ) , but if you try to raise the volume a little bit he fails. dont let the weight fool you , is because have metal cases . the small speakers dont look to bad but are weak . i will stronglly recomend you : DON'T BUY IT . that price (2500 $) on e-bay , is their bs you'll notice , is nothing else about magnum on any other site,comment,review... . hope you read this before you spend your monney .
Reply to vyb
From this website:
http://www.magnumaudio.com/go/about.html
I only get the info of Magnum being a reference site, not selling any speakers. may not be the one you're talking about. But since vyb mentioned something about scamming, you might wanna consider the possibility.
Reply to damasvara
There are 1800 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 9 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
