Advice on parts - changing from Intel to Amd
APPROXIMATE PURCHASE DATE: This week - my current mobo is dying a painful death
BUDGET RANGE: ? Not looking to get everything right now, just the mobo, cpu, and memory
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Digital photography, gaming, audio (iTunes, recording dj sets), movies
PARTS NOT REQUIRED: Keyboard, mouse, case, speakers,
monitor : Samsung T220 Rose-Black 22"
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001273
psu : Thermaltake W0116RU 750W Modular
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153038
WD hard drives:
Caviar Black WD7501AALS 7200
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136283
Caviar Blue WD3200AAJS 7200
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136098
Video Card: BFG 9600 GT 512 256-bit PCIE 2.0
http://www.newegg.com/Product/Product.aspx?Item=N82E16814143130
PREFERRED WEBSITE(S) FOR PARTS: Newegg.com
COUNTRY OF ORIGIN: US
PARTS PREFERENCES: AMD/ATI - would like to eventually switch the graphics card to HD 5850. I would love to upgrade from WXP to W7.
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: Maybe
MONITOR RESOLUTION: 1680x1050
ADDITIONAL COMMENTS:
I'm currently looking at these parts but I'm not sure about the memory compatibility with the mobo..I'm also new to AMD and have had Intel & Asus combos...I'd love to stay away from another Asus board since I've had horrible luck with them as of late. I've read the 955 is bascially the same as the 965...is there a huge performance difference? Is it best to get a different heat sink & fan?
Cpu/Mobo Combo:
Gigabyte GA-870A-UD3 AM3 870
AMD Phenom II X4 965 Black Ed Deneb 3.4
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.436924
or
AMD Phenom II X4955 Black Ed Denebb 3.2
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.436925
Memory - Maybe there is something else that works? I'm not familiar with G.Skill and not sure about the "jaws" making a huge difference
G.Skill Ripjaws 4gb (2x2gb) DDr3 1333 (PC3 10666)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231276
Eventually this card:
Sapphire 100282-3sr Radeon HD 5850
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102884
Thank you for your help & suggestions
3 answers Last reply
More about advice parts changing intel
  1. Well, you didn't give us your budget, so I don't know how much you can spend on this setup...
    I'd really suggest spending the extra $20 and getting the 965 instead of the 955. I know everyone says 'they're the same but the 965 is faster', but they aren't the same. The 965 gives better overclocking headroom than the 955, and is more stable at higher speeds. It's worth the extra money I believe. Of course, if you got the 955, you'd have a little extra cash for a better motherboard... it's really up to you...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727&cm_re=phenom_ii_x4_965-_-19-103-727-_-Product
    Secondly, if you want CrossFireX support, that Gigabyte UD3 won't give it to you, even if NewEgg says it can. At x16/x4 speeds, you'd barely get any performance boost from a second card, if any. Here are my recommendations:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130223&cm_re=AM3-_-13-130-223-_-Product
    Second only to the Asus Crosshair IV, it's still fairly expensive, but offers everything up to quad (x8,x8,x8,x8), triple (x16,x8,x8), and dual (x16/x16) Crossfire. I'm running a P2 x4 965 on it right now, and it absolutely flies. No, it doesn't include USB3.0 or SATA3, but you don't need it right now anyway, and expansion/controller cards aren't that expensive when you do.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130269&cm_re=am3-_-13-130-269-_-Product
    There's another MSI board that supports x8/x8 CFX and is $50 cheaper
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130297&cm_re=am3-_-13-130-297-_-Product
    Here's an interesting board. They're calling it "FUZION" technology which allows you to run ATI and nVidia cards together. I'd probably recommend this one, seeing how you already have a decent card, you could try running it with the 5850 you're planning on getting.
    And if you decide you want something cheap and don't need CFX support, this is an EXCELLENT board for the price:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130290&cm_re=MSI_870-_-13-130-290-_-Product
    As for memory, I'd probably say to just get the fastest RAM you can find in stock. At 7-7-7-21, I'd say go for what you already found. If it goes out of stock, pick up one of these... they're all about equal performance-wise...
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820220407&cm_re=DDR3-1600-_-20-220-407-_-Product
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820226154&cm_re=DDR3-1600-_-20-226-154-_-Product
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820144432&cm_re=DDR3-1600-_-20-144-432-_-Product
    Any thoughts?
    Any thoughts?
    Thanks for the suggestions on the MSI boards and memory. I haven't really considered them only because I wasn't sure they were a good quality company/board. That Fuzion board looks really interesting and definitely worth considering since I would have 2 working cards.
    Again, thank you for the suggestions. I've been reading so many reviews and I'm really new to AMD that this really help a lot!
  3. No problem. :)
    Strangely enough, ASUS is one of the higher quality motherboard manufacturers... you must have had some really bad luck with them. I'm using the MSI 790FX-GD70 right now with an MSI Radeon 5770, and I haven't had a single problem with it yet. It was probably the easiest build I've ever done. Typically, I'd recommend either ASUS, MSI, or Gigabyte boards, but Gigabyte has lost some of its quality in sub-$150 boards recently.
Homebuilt Systems Product
