Hi everyone!
I haven't built a computer for about 8 years (the P4 just isnt cutting it for me anymore) and figured its about that time to put together another one. I really would like to go the SFF route but my biggest concern about this is cooling since everything is in a tight space. I'm still undecided on if I'm going to overclock or not due to more heat being generated from it.
The case I am looking at, NZXT Vulcan, has a 80/92mm exhaust port on the back of it and from what I've been reading, I wouldn't be able to mount a 120mm radiator on the top because or parts getting in the way. After looking around I saw the Coolit Eco A.L.C. C92 (link below) which has a 92mm radiator that I could mount on the back. I was also reading about the Corsair H50 and read that people have removed the front case fan and tray to mount the radiator there since it is 120mm. The build I saw had the gcard in the second slot so that it wouldn't be in the way of the tubes which leads to another question.
Does installing a single graphics card in the second PCIe slot degrade performance as opposed to putting it in the top slot? I downloaded the manual for the mobo and it says that it does but I don't know if that is bs or if performance is affected, that the difference isn't that much. If it isn't, then I will probably go with the H50 as a cooler for the cpu as I believe it would lead to cooler temps. Then I would get a 92mm fan to mount on the back and mount the fan from the front of the case in the second spot up top. I'm hoping that LCing the cpu and filling in the additional fan slots on the case would be enough to keep temps down.
Here is a list of parts below. Feel free to make comments and recommendations on those as well. Budget isn't really an issue and since I obviously don't upgrade that often, I was looking into getting parts that would last me a few years. I plan on buying from NewEgg except for the lc unit(unless I get the H50), which I would have to order from Coolit's site since it isn't released in the states yet. Thanks in advance!
Case
NZXT Vulcan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146065
Power Supply
XFX Black Edition 850W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207001
Motherboard
Asus Rampage III Gene
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131658
CPU
I7 960
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115224
Heatsink
Coolit Eco A.C.L. C92
http://www.coolitsystems.com/index.php/en/eco-c92.html
or
Corsair H50
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010
RAM
6GB Corsair XMS3 DDR3 1333
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145220
Graphics Card
SAPPHIRE Vapor-X 100281VX-2SR Radeon HD 5870
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102872
Hard Drive
Western Digital VelociRaptor WD6000HLHX 600GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136555
Case
NZXT Vulcan
Power Supply
Motherboard
CPU
I7 960
Heatsink
or
Corsair H50
RAM
Graphics Card
Hard Drive
