Hi i have a GA-X58A-UD3R Rev2 , building up a new system. Using a Corsair 650W, HD 5770 . I completed building the setup, i don't know if it has anything to do but i accidentally used used a lower voltage cable for the PSU , the cable that came with it is a 13A 125 V ~ , the cable i plugged in was 10A 125 Volts.
I was able to power up the system just fine, still no OS installed, just reading the BIOS ( to which i made no changes ) . Then i saw that one of the LEDS in the front wasn't coming up ( just a minor thing ) , things is i turned the computer down to see why wouldn't that light come up in the chassis , and when i tried to turn it back on i got two LEDs lit on the motherboard, close to the RAM, i believe they are phase LEDs, there is one green and one yellow. No fans or chassis leds, no sound, no post, just the cpu fan turned on for a millisecond then turned off.
Funny thing, when i disconnect the 8-pin power from the mobo and turned it on, all the computer fans and chassis leds where up and running, but no post. So i don't think there is a short in the board
What could be the cause of all this ???
