Solved
Need Advice on best power supply for this build
6 answers Last reply Best Answer
More about need advice power supply build
  1. Best answer
  2. what makes it much better? I am new to picking out a power supply
  3. the one you chose is gold rated made by super flower but its not one of the better gold rated ones the abs is actually an enermax 1050 with an abs case
    this is whats inside the abs
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817194039
    and a technical review
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=138
    this is whats inside the roswill case
    http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=191
    well is there a good one with LED lights? If i'm going to pay this much for a PSU I should at least get some frizzles
  5. i dunno hey most good companies dont like too much flash you can get the rosewill but know you could have gotten better for the same price the kingwin would also be an option
  6. Best answer selected by ggsxt.
Power Supplies Graphics Cards Build CPUs Components Product
