Solved
Case Cooling
I am soon to be building a new gaming PC and I need help picking between two cases and to find out if the extra cooling in one will make a significant difference specs are as follows:
MOBO: MSI 790X-G45 AM3 AMD 790X ATX AMD Motherboard Link: http://www.newegg.com/Product/Product.a ... 6813130249
CPU: AMD Phenom II X3 720 Black Edition Heka 2.8GHz 3 x 512KB L2 Cache 6MB L3 Cache Socket AM3 95W Triple-Core Processor HDZ720WFK3DGI - OEM Link: http://www.newegg.com/Product/Product.a ... -_-Product
CPU cooling: Sunbeam CR-CCTF 120 mm Core-Contact Freezer CPU Cooler W/TX-2
RAM: OCZ Obsidian 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model OCZ3OB1600LV4GK Link: http://www.newegg.com/Product/Product.a ... 20obsidian
Video Card: HIS H577FK1GD Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity Link: http://www.newegg.com/Product/Product.a ... -_-Product
HDD: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive Link: http://www.newegg.com/Product/Product.a ... 6822152185
PSU: reusing old 500W
DVD/RW: reusing old LITEON
Extra HDD: 1 350GB 1 160GB
The two cases I need to pick from are:
http://www.newegg.com/Product/Product.a ... 6811103030
http://www.newegg.com/Product/Product.a ... 6811146041
I like the looks of the NZXT one and if I get it I plan on installing a third 120mm front intake fan but I am wondering if the cooling system on XClio will be significant over the NZXT. Thanks in advance.
I also plan on doing a little overclocking including attempting to unlock a fourth CPU core.
36 answers Last reply Best Answer
More about case cooling
  1. Best answer
    I would go with the XClio or look a this Cooler Master case, which is a nice mixture between your two cases but overall is a better case... IMO
    Cooler Master RC-690
  2. Thanks for the recommendation I think I will get the cooler master although I wish it had a side window but that isn't all that important.
    i have the exact same case.. and i can vouch for it and say that it is worth double the price tag.. pleanty of room.. great cooling.. great price.. and its sleek looking without being too "ricer" or "loud"..
  4. If it ever does become important they do make side windows for RC-690 cases - this one is about $25:
    http://www.amazon.com/RA-690-KWN2-GP-Transparent-Acrylic-Refund-Replacement/dp/B0028UEYVQ
    wr2.. this isnt my thread so i cant vote you best answer.. but if it were.. i would :D.. i had no idea that they made these for my case.. im gettin it :)
  6. The CM 690 is a high quality case i know cuz i have a 690II.
    Just add the side panel.
    http://cmstore.coolermaster-usa.com/product_info.php?products_id=322
  7. +1 for the good price.
    I hope jesman1985 sees the bargain price @ the CM store.
  8. Thanks for all the help. Really impressed with the forums, its gonna be tough to pick best answer.
    Yeah! the CM website and store prices are amazing.
    Antec's new website leaves alot to be desired it's worse then the old one.
  10. I have another quick question is it a good idea to get the CM 690 II over the original?
  11. the only difference i see is the black interior.
  12. CM690 II Advanced does have free shipping so the price difference is only $18 with shipping factored in.
    If you are really interested in a side window it does dress up the overall look of the case.
    There are a few little nice upgrades on the CM690 II Advanced that have been popular with owners.
  13. COOLER MASTER CM 690 II Basic has free shipping so its actually less expensive in total than the RC-690
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119215
  14. but the basic only comes with 2 fans right?
    it can take 2 on the side.. 2 on top.. 1 exhaust..1 in the front cooling the HDD it has a blue led.. plus the heatsinks fan and the one on your video card.. WAYY more than enough.. oh and one on the bottom by my the power supply.. but all im using is 2 on the side.. 1 exhaust and one on the bottom by thew psu,, and the one in the front.
  16. no i ment the included with the basic are only 2
    and if u add all those fans it will cost $100 ++
    normally it comes with 3 .. one in the fornt, side and exhaust.
  18. that's a good number of fans for the price
  19. I think I will go with the CM 690 II advanced and get the side panel with it. Does anyone have any suggestions for HSF for overclocking a phenom II and unlocking a fourth core?
  20. A fourth core unlock is a function of the motherboard. Have you picked one of those out yet?
  21. Here is a NewEgg combo deal: Athlon II X3 445 Rana 3.1GHz and COOLER MASTER Hyper 212 Plus CPU cooler $123 ($12 discount)
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.459623
    or Athlon II X3 440 Rana 3.0GHz and ASUS M4A89GTD PRO/USB3 AM3 890GX SATA 6Gb/s USB 3.0 MB combo $210
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.456247
    nice choice.. you can go pre liquid cooling.. the H50 already comes with everything set up.. you just screw it in and its done. http://www.newegg.com/Product/Product.aspx?Item=N82E16835227006
    or if your going air this is the best air cooler on the market today.. it even beats the v8, v10 air cooler in actual study.. and the v10's running at like 120 bucks..
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835608016
    personally i'd go with the air cooler.. i dont want to have to worry about that h50 springing a leak 2 years down the road..
  23. definatlly avoid that h50 it sucks at cooling.
    Yes I have already purchased a mobo with the CPU core unlock capability.
    I would also prefer a HSF that doesn't cover any of my RAM slots although if its a good enough bargain I would be willing to sacrifice this requirement.
  25. As for the heat sink... I'm a fan of the Sunbeam CR-CCTF for any AM3 build.
  26. also you should consider the zalman cnps10x preforma
    That was my original choice and I may still go with it, my only problems are its size and the reputation of sunbeam for rebates and warranty's and things of that nature.
  28. You always have the Cooler Master Hyper 212 Plus from Amazon.com, MicroCenter.com or TigerDirect.com, all of which have it cheaper than Newegg.com
  29. Is that the MSI 790X-G45? I didn't know it had the core unlock feature.
    I'm trying to check the RAM slot clearance of the HSFs being talked about.
    Just need to be sure which MB to check.
    Yes that would be it and it has a BIOS option to unlock CPU cores if im not mistaken. Also whats the reliability on refurbished items from the cooler master store?
  31. Better than average. I got two of the RC-690s there 2 years ago. Slight cosmetic imperfections in out of the way places was all I noticed. A few scratches on the side panel were touched up nicely.
    I saw the NewEgg customer comments about the core unlocking utility.
    I normally use the NewEgg customer comments to scope out what coolers fit specific MBs and Im not finding any help there.
  32. So it would be ok to get a refurbished HSF and or case from them?
  33. Best answer selected by Bcknee.
New Build Cooling Cases Systems
