renco55
5
Hello,
I have just put new system together
MB- M4A87TD/USB3
ram- Patriot viper extreme pc3 16000 2000 Mhz 3x4 +12 gig
cpu- amd Phenom ii x4 black edition 3.4 Hz
The system will boot after a long time but the ram light on MB will go on and off with 2 sticks of ram in but won't boot with all 3 sticks in.
also noted during slow boot the errors of - EC flash corupt and over voltage
any ideas what the problem can be
renco55
5
yes that is the ram I have
Thanks for the reply mosox....I set the voltage to 1.65v and it seems to work ok...except only with 2 sticks of ram in I believe the third stick is bad,I tried it by itself and in combo with the other 2 sticks and that would stop the system from booting up. However it works fine with 2 of the 3 sticks.I'm doing a memtest with linux live cd and it shows the ram at 568 Mhz
Thanks alot for your time and help
