Starcraft 2 build, $650, have a few parts already
APPROXIMATE PURCHASE DATE: This week or next
BUDGET RANGE: $650
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: HD video and Starcraft 2
PARTS NOT REQUIRED: Hard drive, power supply, keyboard, mouse, monitor, optical drive
PREFERRED WEBSITE(S) FOR PARTS: Newegg preferable, but not necessary
COUNTRY OF ORIGIN: USA
PARTS PREFERENCES: Will be using a Core i series processor and a GTX 460 video card
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1680x1050 minimum
ADDITIONAL COMMENTS: Have a configuration in mind, just want thoughts and possible price saving suggestions
My intial configuration through Newegg is below. It's pretty straightforward. As I only need RAM, video card, CPU, case, and motherboard for now, I'm just looking to tweak this. I went with a high clock dual core CPU as the only game I'll be playing is Starcraft 2, and won't need anything better for everyday computing/HD video watching. I figured the GTX 460 was the way to go, from all accounts, as far as price/performance ratio goes.
Basically, I just want to see if anyone has the ability to tweak this configuration to save a few bucks, or get a little more performance at this price range.
Thanks in advace!
UPDATE: Wrong GPU on price list, should be GTX 460 1GB
5 answers Last reply
More about starcraft build parts already
  1. might want to consider amd. and that gpu is old and sucks
    here is a build for $637.95 before $20 rebates and it's sli ready
    case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811163168 (great quality cooling black interior and cable manegement)
    mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130235
    gpu: http://www.newegg.com/Product/Product.aspx?Item=N82E16814125333 (this beats the 5850 in sc2 if oced and u can turn on aa)
    ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820226154
    cpu: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
    here is the reason why to get the gtx 460
    http://www.hardwarecanucks.com/forum/hardware-canucks-reviews/34344-starcraft-ii-gpu-performance-comparison.html
    also this build is sli ready and your build isn't also this is more future proof
    also if u sli the gtx 460 it can be slower than the 5970 by 1-7 fps
  2. So you want to spend $180 for a Dual core CPU? LOL? SC2 requires lots of cpu power from what i have heard. Quad is recommended.
    Fine i will give you a Intel and AMD build for you to decide between.
    Keep the Case, ram and Graphics Card.
    Intel:
    CPU $195
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
    MOBO $110 (i love MSI, it slightly cheaper, but you can use either MOBO)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130240
    $5 more but tons more performance.
    AMD:
    CPU Option 1 Quad Core 3GHZ $140
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103809
    Cpu Option 2 Tri Core 3GHZ $77
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103843
    Mobo $70
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130290
    The AMD route offers slightly more performance than your original build at about $100 cheaper, if you must pick intel at least get a quad, but the amd will save you money.
    Read this: http://www.techspot.com/review/305-starcraft2-performance/page13.html
    Starcraft 2 only utilizes two cores. More important is the clock speed.
    Thank you both for the suggestions. mrhosos96, I don't know what I was smoking. I entirely meant to select a GTX 460 as per the Techspot review I mentioned above.
  4. So you will have a fresh install of windows and never run anything besides sc2? I dont believe how games only use 2 cores, EVERY game i ever played always uses 4-5 cores of my 6. From WOW to warcraft 3 to duke nukem, from a windows 95 monopoly to crysis. I have yet to play a single or dual threaded game.
    If you look the processor i recommended will outperform the one you suggested.
  5. games don't more than 4cores
    and the build i mentioned is more future proof and u can sli in the future
New Build Starcraft 2 Systems Product
