This has me puzzled. I just bought a Gateway computer, an FX 6840-23, Intel i7, 1 TB HD, 8 GB, ATI Radeon HD 5750 GPU. The GPU connections on the back are 1 DVI and one VGA. I use the DVI connection. No problem.
Their is a huge problem I see in this higher-end computer supposedly made for media type work like editing photos and video, which is what I do, as well as being a writer, and it has great gaming uses, not so much as a hiccup so far with settings maxed out on FSX, CoH, Crysis, etc.
The problem? A little stinkin' stereo jack on the back of this computer. I was dumbfounded. I have a 5.1 surround sound system that I have no idea on how to hook it to this computer without buying a sound card. You would think that the jacks would be standard as they are on my other Gateway Intel Quad Core computer.
Can anyone give me some direction on what I need to do?
Thanks
Thanks
