In need of help building a budgeted gaming system (amateur)
Last response: in Systems
Hello - I created this thread because I need guidance on building a gaming desktop. I don't have much experience with this - the only thing I know is about what the components actually do.
My goal is to make a great GAMING PC for myself for about 600-800$ - I want to try to not go over 700 but i also want to get the most out of my money. I am using websites such as google, newegg( especially the reviews!). I won't get state of the art technology with that budget, but I still want it to last a good number of years with the latest games. I live in and will be buying from the USA.
Keep in mind that since i have never built a computer so I'm not really sure too what I'm doing. I figured that I would order all the parts and then just try to put it together.
So far, the parts that I think I need are:
Processor
Motherboard
Video Card
RAM
Monitor
Computer Case
Hard Drive
CD/DVD Burner
I have done a little researched on the processors and I would prefer to have an intel over amd.
I have narrow it down to two processors but not sure which one is better and more worth the money. please help.
1. Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor BX80605I5750 ( http://www.newegg.com/Product/Product.aspx?item=N82E168... )
2. Intel Core 2 Duo E8400 Wolfdale 3.0GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor BX80570E8400 ( http://www.newegg.com/Product/Product.aspx?item=N82E168... )
And the following items I chose out of best ratings and mostly positive reviews. Please give me your honest opinion.
Motherboard - ASUS P5N-D LGA 775 NVIDIA nForce 750i SLI ATX Intel Motherboard
Video Card - ASUS EN9500GT/DI/1GD2/V2/A GeForce 9500 GT 1GB 128-bit DDR2 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card ( http://www.newegg.com/Product/Product.aspx?item=N82E168... )
Ram or Memory - I was not really sure if this was the best one. Any better memory or about the same price I can use?
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ ( http://www.newegg.com/Product/Product.aspx?item=N82E168... )
Monitor- I currently have a Vizio 32', hopefully I can use that as a monitor. If you know any good deals. Please help me out! Greatly appreciated
Computer Case (Chassis) - Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case ( http://www.newegg.com/Product/Product.aspx?item=N82E168... )
Hard Drive- Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive ( http://www.newegg.com/Product/Product.aspx?item=N82E168... )
CD/DVD Burner - ASUS black 24X DVD ( http://www.newegg.com/Product/Product.aspx?item=N82E168...
I probably would not be overclocking (OC) it just simply because I don't know how or even know what that means =/
I'm not too concern about keyboard and mouse but if you know tips, please post.
Let me know if I left out anything. I really appreciate the help. Thanks a lot for posting!
Looks like I'll be watching your thread as well as I'm looking for about the same thing !
Processor
Motherboard
Video Card
RAM
Monitor
Computer Case
Hard Drive
CD/DVD Burner
I would go with the i5 750 over the EOL E8400 but for a gaming system your lacking GPU power maybe look into a build like this.
SAMSUNG CD/DVD Burner Black SATA Model SH-S223C - OEM
Item #: N82E16827151192
Return Policy: Standard Return Policy
Protect Your Investment (expand for options)
$19.99
Item #: N82E16811129066
Return Policy: Limited Replacement Only Return Policy
-$15.00 Instant $69.99
$54.99
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822148395
-$5.00 Instant $59.99
$54.99
GIGABYTE GA-890GPA-UD3H AM3 AMD 890GX SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
Item #: N82E16813128435
$139.99
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
Item #: N82E16814102873
Return Policy: VGA Standard Return Policy
-$25.00 Instant
$15.00 Mail-in Rebate Card
$174.99
$149.99
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 ...
Item #: N82E16817139005
-$30.00 Instant
$10.00 Mail-in Rebate Card
$119.99
$89.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM
Item #: N82E16820231303
Return Policy: Memory Standard Return Policy
-$10.00 Instant $114.99
$104.99
AMD Athlon II X3 445 Rana 3.1GHz Socket AM3 95W Triple-Core Desktop Processor ADX445WFGMBOX
Item #: N82E16819103872
Return Policy: CPU Replacement Only Return Policy
$84.99
Subtotal: $699.92
Related ressources
He said 600-800 but wanted to stay closer to 700 ( So its 101 more ) but yes i do agree if he wanted to max out the budget, he would be better off in the long run with the 955 and the GTX 460
I have a questions with regards to INTEL i5
what is a better chip. i5 LynnField, Clarkdale, or Arrandale for gaming?
I was looking at this one I have a questions with regards to INTEL i5 Lynnfield 2.66ghz
Please see if this is a good SET-UP.. I'm open for opinion
CPU – $209.99
Motherboard –$119.99
http://www.newegg.com/Product/ProductReview.aspx?Item=1...
Video Card – $109.99 (plus shipping $7 )
Power Supply – $89.99 ($20 mail in rebate - $69.99) Shipping $3.99
RAM (memory)- $ 97.99 http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Harddrive - $74.99 (promo code EMCYWYP32 $20.00 off )
CD/DVD Optical Drive – $18.99
Computer Case (Chassis) – $69.99 (shipping $9.99)
Monitor – 32” Vizio TV 720p with RGB and HDMI input
Total = $812.90 cents
-$20 promo code
-$20 mail-in-rebate
$772.90 cents
About wireless, I need Ethernet cable and a router? I cant get like an internal wireless adapter for it to work? Cuz its cheaper that way.
I have reconsider, I will be going with the AMD Phenom X4 965 or 955 BLACK EDITION... what is a good MOBO, RAM, and Video Card to use.. and i'm thinking about getting a CORAIR cpu cooler to fit in my ANTEC case??? ANY SUGGESTION?? I'm in need of a PC LOL
If you read the post there are AMD mobos ram and gpu that we posted
Okay! I am going with the AMD PHENOM II X4 965 Black Edition.
I need a motherboard that will last and is good for playing starcraft 2. If the motherboard has a onboard video card HD 4290.. do I need to get another video card to play Starcraft 2 and use it?
Here are the list I came up with. (cannot decide)
I'm ready. i hope this is the best list
CPU AND MOBO $289.98
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
RAM $ 93.99
Power Supply – $89.99 ($20 mail in rebate - $69.99) Shipping $3.99 ($10 off w/ promo code EMCYWYP25)
Sub-Total - $731.92
-$20 MIR
TOTAL = $711.92
Ask the community
