Solved
Can i replace power cable Sata to old one?
Last response: in Components
Anonymous
a b ) Power supply
October 6, 2010 7:30:46 PM
Hello. I bought new Power Suply as my old was, well old. When i wanted to connect it to my computer i discovered that this Power Supply have only two power cables that can fit my WD ATA 80Gb hard disk and my Graphic card. Power supply also have 3 more power cables but their ends are for new hardware (Sata). And now my second Hard Drive and DVD RW are not powered.
Can i just take ends of my old Power supply cables and rewire to this SATA endings that i cant use? Is it same, or they are different in some way ?
Thanks
Best solution
a c 104 ) Power supply
October 6, 2010 7:33:04 PM
http://www.amazon.co.uk/SATA-to-Molex-Power-Adapter/dp/...
might be your best bet, i wouldn't try adapting the power psupply lines unless your a very knowledgeable electrician
Moto
a c 144 ) Power supply
October 6, 2010 7:44:00 PM
Can you? Yes.
Should you? No.
m
l
Anonymous
a b ) Power supply
October 7, 2010 9:55:58 AM
Thanks guys, i was not aware that this splitters exist :wahoo:
m
l
Anonymous
a b ) Power supply
October 7, 2010 12:18:39 PM
Best answer selected by Iwchas.
m
l
October 7, 2010 4:46:32 PM
Thank you for B.a., hope you get sorted ok man
Moto
m
l
