Sign-in / Sign-up
Fan makes a loud noise when starting sometimes
  • Power Supplies
  • Switch
  • Fan
  • Components
Last response: in Components
October 7, 2010 8:51:52 AM
Hi - bit of a noob question really:
When I switch my PC on, sometimes the fan makes a loud noise when starting - it doesn't boot when this happens.... so, I switch it off, and switch it on again and then it's silent and boots up.
Sometimes I have to switch is off and back on a few times so the fan stops making a loud whirring noise (sounds like it's whizzing away) before it'll be silent and boot correctly.
The fan is a Cooler Master GX 750.
Any ideas? All help appreciated. Thanks!
More about : fan makes loud noise starting
a b ) Power supply
October 7, 2010 11:00:30 AM
Check to see if no cables are obstructing the fan.
