Advice on system
Parts:
Mobo: EVGA P55 FTW SLI Motherboard
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5083734&sku=E145-2074
CPU: Core i5 760 Lynnfield 2.8GHz Quad Core
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6524800&sku=I69-0760
Memory: Corsair Domintor Dual Channel DDR3 1600MHz 2x2048MB
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6044636&sku=C13-6181
GPU: Galaxy GeForce GTX 460 GC
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=6589096
PSU: Cooler Master Silent Pro M850 Modular
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5309345&sku=C283-1228
HDD: Seagate Barracuda 1TB 7200rpm
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4691122
Case: Cooler Master HAF 932 Full Tower
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4146085
Uses:
Gaming mostly, I play both GPU intensive FPS games and CPU intensive RTS games. I dabble a bit in video editing but nothing too serious there.
Planned upgrades:
Once I recover from the initial bill, I would like to purchase another 4GB of the same RAM, a fan controller and another GTX 460 for SLI. Also, I would like to invest in a nice after-market cpu cooler so I can dabble in overclocking somewhere around 3.5GHz in hopes that my cpu can keep up with the rest of the system.
My Thoughts:
PSU: I think I am going overboard in the beginning. However, I wanted enough headroom on the PSU to complete all upgrades listed above and still be okay with regards to power. The PSU calculators I used have me needing somewhere between 800w and 1000w once all upgrades are complete. It looks like the 12v rail has good head room but will 850w be enough when I am all done?
Mobo: Once again I think that I am going overboard here. I do not anticipate on ever using much of the customization power this Mobo provides, but I would like a nice Mobo that I can play around with and break my OCing cherry =).
CPU: Will the i5 760 be good enough to keep up with the rest of my system? Should I just throw down another $100 for an i7 and wait a bit longer for the upgrades?
Its my first time, go easy on me!
4 answers Last reply
More about advice system
  1. A few things u should know about SATA/USB 3.0 tech and mobos as shown by our very own forums here
    USB 3.0, SATA 6Gb/s, Motherboards, And Overcoming Bottlenecks
    http://www.tomshardware.com/reviews/usb-3.0-sata-6gb,2583.html
    Also note that LGA 1156 shall be usurped by LGA 1155 as soon as end of this year/possible Q1 next year if u intending to sink a wee bit on chip + board FYI...
    http://www.bit-tech.net/hardware/cpus/2010/04/21/intel-sandy-bridge-details-of-the-next-gen/
  2. That RAm is not worth the money. Better off with a sec of G Skill Eco's. Lower voltage, cheaper and better timings.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231321&cm_re=eco_4gb-_-20-231-321-_-Product
    Get a 1gb GTX 460, same price as that factory OC one you're linking.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130565
    Also, I wouldn't go with the PSU, it's made by Epsilon...
    For the money, you're MUCH better off with a XFX 850 made by seasonic. $130 after rebate.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207001&Tpk=xfx%20850
    The HAF 922 is cheaper and essentially the same. You really don't need anything bigger as the 922 is larger than many full tower cases already.
  3. Update (because I noticed the preferred template after I posted and some things have changed)
    APPROXIMATE PURCHASE DATE: less than two weeks
    BUDGET RANGE: about $1500 before rebates
    SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Movies, Little bit of video editing.
    PARTS NOT REQUIRED: I need everything.
    PREFERRED WEBSITE(S) FOR PARTS: Wherever I can get them cheapest + with decent return/RMA policy
    COUNTRY OF ORIGIN: USA
    PARTS PREFERENCES:
    Current Thoughts:
    Mobo: EVGA P55 FTW SLI Motherboard (Anyone recommend a more conservative one?)
    CPU: i7 860
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4959972&sku=I69-0860
    Memory G. Skill ECO 2x2GB DDR3 1600MHz
    GPU: EVGA GTX 460 1GB DDR5
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814130565&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
    PSU: Still comparing options….
    Monitor, disk drive and others I can figure out on my own.
    OVERCLOCKING: In the future yes: Def the processor, maybe the memory and video card if it seems needed.
    SLI OR CROSSFIRE: If I manage to stick to my budget then I’ll be buying a second card within a month of getting the system.
    MONITOR RESOLUTION: Don’t have a monitor yet. The one I am considering is 1920x1080
    ADDITIONAL COMMENTS: Once my wallet recovers I plan on another 4gb ram, a second video card, and a nice CPU cooler.
    Batuchka: What I take away from those articles is that if I wait a little bit, prices on the mobo + processor that I want will drop. It seems to me that in the world of computing there is ALWAYS the next best thing around the corner so I don’t really think I should go too far out of my way waiting for this stuff to come out…
    Banthracis: Thank you very much! I agree with you 100% on the RAM. The GPU you linked is actually $30 more than the one I was considering (after rebate) but it seems well worth it (EVGA and more mem). With the PSU: the XFX looks nice but I am a little nervous sticking with a psu that has maximum 850w. I don’t have much experience with this but all the calculators I have used put me right at 800-900 with everything maxed and I would like more headroom than that. I plan on pushing this thing pretty hard… thoughts? I am going back and forth on the case, I saw the 922 as an option from the beginning, but the 932 has nicer fans and it looks a little better imo. Prolly not worth the extra $$$ at all but I am a sucker for looks. I’ll consider it some more. Thanks again for your comments.
  4. You can sli gtx 460's on a 650W PSU. 850 is way overkill already.
    Best P55 mobo would be a Asus p7p55D-E Pro $180
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131621&cm_re=p7p55d-e-_-13-131-621-_-Product
    You can also knock down the price by grabbing some combo deals.
Homebuilt Systems Product
