After alot of research, I've come down to this. But since this is the very first PC I will build, I ask for your opinions in case I have done any "mistakes".
Will these components in my first self-built PC work well together?
OS Windows 7 Home Premium
Cha. Fractal Design Define R2 Titanium Grey (Elegant and silent. In other words - perfect!)
Proc. Intel Core i5 750
RAM Corsair XMS3 DDR3 1600MHz 4GB (2x2GB) CL9
Moth. Gigabyte GA-P55-USB3, P55, Socket-1156 or Gigabyte GA-P55A-UD3 or ASUS P7P55D, P55, Socket-1156 (what is really the difference?)
HDD Samsung SpinPoint F3 1TB (Everybody says it's better than any other HDD, but why? And what is RAID?)
GPU XFX Radeon HD5770 (I won't play a lot of games, but I'll be using two monitors, so I think this will work great)
DVD-RW Does'n matter as long as it's cheap. I'll pick the a cheap one after being sure about all the other components.
PSU Corsair TX 650W (It's expencive, but stable)
Processor Cooler? Will I need it? I think "no".
What do you think? Please give me some response about how the components will fit each other. Any input is appreachiated.
Thank you very much!
