http://www.youtube.com/watch?v=V6bCoNUmd-8
CPU fan reached 6krpm and is real loud. problem? can i turn it down? 3k rpm was more or less quiet.
the cpu temp - 49c
system temp - 36c
(this is while viewing the bios)
i think the hdd isn't getting power (only connected SATA cable), but not sure which cable i need to hook it up and where to hook it up to.
Any idea what the extension cable for the cpu power is called?
If you spot anything else bad, let me know.
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130269
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
I really want to get this working. I input my windows 7 and all it needs is a hard disk to be found for installation (i hope).
the cpu temp - 49c
system temp - 36c
