Solved
Need a new power supply for Dell Inspiron 530s.
  • Power Supplies
  • Dell Inspiron
  • Components
  • Product
Last response: in Components
October 9, 2010 4:08:31 AM
I have a Dell Inspiron 530s. Due to my dog peeing on it, it needs a new power supply. It has a 120w 24 pin power supply. I'm a bit short on money at the moment, so cheap as possible is best, and I'm just not that familiar with buying online. Any suggestions would be greatly appreciated. Oh, the current power supply has the model number dps-250ab-28-b and is made by Delta. And again, thanks.
More about : power supply dell inspiron 530s
Best solution
a c 723 ) Power supply
October 9, 2010 12:51:36 PM
Here is a TFX PSU which is the same form factor http://www.newegg.com/Product/Product.aspx?Item=N82E168... from a quality manufacturer.
October 9, 2010 1:57:40 PM
Alright, cool. Much cheaper than the OEM ones i was finding. Thanks for the help.
m
l
October 9, 2010 1:58:07 PM
Best answer selected by HmmIDK.
m
l
