Tom's Hardware > Forum > Games General > Games General Discussions > help... when I select certain maps that used to work the g..
Forum Games General : Games General Discussions - help... when I select certain maps that used to work the g..
Archived from groups: alt.games.unreal.tournament (More info?)
mac system 9 ... please help... when I select certain maps that used to
work the game quits. worked fine before on my old HD but I had to get a
new one.... I reinstalled everything but now when I try to play the
newer maps the screen just fades out and the program quits... any ideas
on how to fix this would be appreciated.... it quits when I try to play
Anubis, Veridian or August Moon... my fave, and others .... I'm
thinking it may be a texture that I'm missing but I can't find it... it
fades out even when I go through the game selection menu as well...
Thanks
samurai_ess@yahoo.com
aka billclinton
aka lemonysnickett
BEST!
Sponsored Links
samurai enlightened us with:
> to work the game quits. worked fine before on my old HD but I had to
> get a new one.... I reinstalled everything but now when I try to
> play the newer maps the screen just fades out and the program
> quits...
Check the log file in ~/.loki/ut/System/UnrealTournament.log and see
what it contains.
MeltDown
!For all your UT99/2k3/2k4 questions visit UnrealTower's FAQ section:
! http://www.unrealtower.org/faq
!Home of the FAQs for agut and agut2003.
Reply to Meltdown
Thanks for the reply but I'm not sure where to find that unles you mean
to type that into the system console when the game is running.... I
tried that and got an "unrecognized command" back
Best,
Samurai
In article <slrnck8a6v.irs.meltdownUSE@sybren.thirdtower.com>, MeltDown
> > quits...
> what it contains.
> MeltDown
Reply to Samurai
Please stop top-posting. I've fixed it for you.
>> see what it contains.
Well, I assumed that Mac stores the logfile in the same location that
Linux does. Just search your system for UnrealTournament.log and it
should show up.
> unles you mean to type that into the system console when the game is
> running....
In that case, I'd tell you "type 'this and that' in the UT console",
not "check the log file".
Please, next time, think about the way you post. Many people don't
think about this and put their reply at the top of their post, quoting
all of the original post below it. Now take a look at this:
> Why is top posting so hard to read?
> > > What is one of the most annoying responses on Usenet?
> > When they top post.
In the English speaking world we read left to right, top to bottom.
If people do it the other way around, things will clear up instantly:
> > When they top post.
The best response type is "in-line" posting, that is, remove all the
quoted text that does not apply to your response, adding your comments
in context underneath as you go.
The distributed nature of Usenet is causing that not everyone sees all
posts in a particular thread in the right order or or even at all. If
you make sure you put your reply in a top-to-bottom order, people will
be able to easily read through it from top to bottom.
Be sure to remove all excess quoted text though. There is nothing more
annoying than having to scroll down three pages of quoted text you
already read, just to read a two-lined reply ;-)
A more complete guide to posting to Usenet can be found at
http://www.netmeister.org/news/learn2quote.html
The relevant section on good posting form is here
http://www.netmeister.org/news/learn2quote2.html#ss2.3
MeltDown
Reply to Meltdown
> Log: AttemptFullscreen
> Init: Initializing Rave...
> Init: Rave engine found = ATI 3DRage QD3D Rave Engine
> Exit: Preparing to exit.
This is weird. UT attempts to go fullscreen, and immediately after
that it exits. Try setting up the game so that it doesn't start in
full screen, and try again. You can do this by editing
UnrealTournament.ini, which you'll find in the same dir as the log
file.
> Sorry I don't post much so I didn't know... Was this one better?
Beautyful :)
MeltDown
Reply to Meltdown
I tried your suggestion and the game started in small screen mode then
I selected one of the maps that I can no longer play and the game quit
again. Any other suggestions? Thanks for helping
S
> file.
Reply to Samurai
> file.
S
Sorry I top posted again on that previous one
S
Reply to Samurai
> then I selected one of the maps that I can no longer play and the
> game quit again. Any other suggestions? Thanks for helping
Ok, so it's not a fullscreen-related issue. I'm drawing a blank here -
perhaps you could contact the map authors?
MeltDown
Reply to Meltdown
I'm thinking that it could be a texture related issue.... perhaps I'm
missing something used in the newer maps and that causes the crash....
the thing is I used to be able to play them all and I reinstalled
everything I had... 3 times even but still no luck.....
Thanks for the help.... I'll keep trying
Best,
Samurai
Reply to Samurai
There are 1248 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
