Hello everyone, this is my first here and i really need some help because i'm getting mad here...i'll follow with what's going on on my computer.
FIRST NOTE: I know you'll find what i'm going to state familiar but trust me...i ranned Google upside-down, read topics all over and nothing helped...please read the following...i'm desperate =/
A few days ago, with no previous reason or justification for it, when i pressed the "Start" button on the case something awkward happens since then,
computer turns on normally, after 3 seconds more or less it shuts down and again, automaticly, after being shut down for a couple of seconds it starts up alone and then keeps working but without any boot or system activity, screen led is orange, no activity, no message. All case fans, PSU, CPU, GPU are working, no strange sounds on them...just stays there with power on, working but no movement or activity, it's like it's just connected to power without any work from hardware/software/BIOS at all.
Details, besides what was mentioned above:
Computer specs are:
- Motherboard ASUS P5Q PRO TURBO;
- Intel Core 2 Duo Skt775 E8200 2.66Ghz @ 1333Mhz FSB;
- ATi EAH5670 PCI-E 1Gb GDDR5;
- 4Gb RAM DDR2 Dual-Channel Kingston @ 1066Mhz (4 slots of 1024MB);
- HDD Seagate Barracuda 250Gb 7200rpm SATA2;
- LG DVD Drive 16x;
- ASUS DVD-RW Drive 16x48x;
- Case Tacens Audeo with 1 front fan, 1 back fan, front Firewire port + USB 2 ports + Audio pannel (input and output);
- Screen/Monitor ASUS LCD 19" VGA/DVI connection (DVI adaptor connected to GPU);
- Keyboard Logitech 600 USB corded;
- Mouse Logitech Laser USB corded;
- Win 7 64x i was using (for months without a single problem).
After starting, shuting down after 3 secs +/- and restarting automaticly and then staying like idle just powered with no activity:
1. Motherboard LED shows green light
2. PSU, CPU, GPU and case fans work properly, lights on the fan on and LED keeps on - except front pannel lights, POWER GREEN LIGHT doesn't turn on, the YELLOW PROCESSING LIGHT works for a few moments then turns off aswell - but then again, there's no activity;
3. HDD vibrates and seems to work, but nevertheless, as long as it gets power supply it can function but not work;
4. There are no beeping sounds - apparently RAM, GPU, HDD and CPU are working fine - although there is no beeping sound at all when starting both times;
SO FAR THIS IS WHAT I TRIED:
A. Tested a new PSU -
same problem persists;
B. Got a new motherboard, the one i mentioned above (previous was ASUS P5K-EPU) -
C. Removed all the cables leaving only the PSU connections to the motherboard, HDD and DVD drives - this includes the USB (mouse, keyboard, external HDDs, print, speakers, microphone, LAN cable) - leaving only on the back the power cable and monitor cable at GPU connected -
same problem persists - with the new and old motherboard;
D. Internaly removed the front pannel audio, USB, 1394, PWR LD, HDD LD and SPEAKER cables from the motherboard - leaving PWR SW and RESET SW - (yes no beeps even with the SPEAKER CABLE connected, i tested it
same problem persists - with the new and the old motherboard;
E. CPU with the old motherboard and the new motherboard was the same, even changed the heatsink and got it thermal pasted again to check (confirmed that is correctly inputted and held) -
F. PSU same issue with the motherboard and components before as with the new motherboard -
G. Changed DVD drivers cables with a new one, the one that came with the new motherboard -
H. Changed HDD SATA cable with the new one that also came with the new motherboard -
I. Tried even running the computer without GPU and HDD -
J. RAM was changed into the new motherboard when changed, no issues with it apparently, before and after the new motherboard, same thing basicly -
K. Checked both motherboards for burnt parts or slots, nothing found -
L. Tried my old GPU ASUS ATi EAH3850 PCI-E 512MB GDD3 with side power connection on (it has a side powersupply connector at the edge of it) -
M. Removed the B-channel RAM from the slots, running only A -
N. Removed the A-channel RAM from the slots, running only B -
O. Removed all the 4 RAM from the channel slots -
same problem persists - strange finding, there are no beeps! - onboard SPEAKER CABLE is connected before these RAM tests;
P. Tried starting without HDD -
same problem persists - no beeps;
Q. Tried starting without GPU -
Is the speaker creating a shortcut as a problem? If so the system should be continuously shutting down and restarting which just happens one time like mentioned above several times.
Honestly guys i'm gettin desperate cuz i can't find the problem...and no freakin solution
Thank you all from the start...i'm really hoping someone can help me with this...my guts tell me it's some electric/electronic issue...but can't solve it...
Cheers
