Problem during boot with my new(ish) home build.
Last response: in Systems
August 4, 2010 10:48:03 AM
Hey TH peoples.
So, I built my first computer a month or two (or maybe three) ago and all has been running brilliantly so far.
No issues, and I'm loving it.
However, yesterday something interesting happened.
When I boot the computer, it appears to freeze (or pause) during the startup and then continue as usual about 5 minutes later.
Once I press the power button, this screen appears within 5 seconds (as it always has).
However, it then pauses for a number of minutes before the rest of the screen loads.
Showing this:
What normally (used to) happen is that the first of those screenshots only appears for a few seconds and then the rest of the screen loads.
So.
Any idea why the few minute gap?
My system is:
i7 930
Gigabyte x58a ud3r
3x 2gb of Corsair memory
Radeon 5850 1gb graphics card
Thanks in advance.
-B
August 4, 2010 2:23:22 PM
It would look to me like it's looking for an optical drive....as I see none listed!
That's your delay.....do you have a dvd/cd rom drive connected?
m
l
August 4, 2010 4:30:19 PM
I do.
That would be the Asus DRW-24B1ST...
Which seems to work fine once the computer has started...
-B
m
l
August 5, 2010 1:13:40 AM
is it sata? or ide....
this could be your problem...
If it's an IDE drive then set it to master...
m
l
August 5, 2010 2:16:42 AM
It's SATA...
When I first did the build I asked a bunch of times about it being Slave and whether that was an issue but no-one was able to give me an answer on it.
-B
m
l
