Hey all, quick question. I am running 6GB 1600Mhz tri-channel on my board. I'd like to go to at least 8 (maybe 10) but my board can only do a max of 3 modules in tri-channel config. So if i upgrade the memory i will be downgrading to dual channel. The 6GB i have is from a tri-channel kit, so i don't want to buy another kit (i know you can get larger kits) because i'd basically be throwing money down the drain. So i'm left with what i have or having more memory but no tri-channel. Anyone on here have any recommendations which is better, to have 10GB dual or 6GB tri? Thanks!
