Hello,
On my motherboard the sata controller is broken so I was wondering if I bought a sata controller card like this
http://www.newegg.com/Product/Product.aspx?Item=N82E16816124045
Here is my motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
If I bought that sata controller card and put it into the 2.0 PCI slot and plugged in my 3.0gb 1tb Samsung HDD, and my sata DVD drive would it boot windows and work correctly? Also if it did work would the performance be just as good as the on board sata, sources online say its better others say sata controller cards aren't?
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
DVD drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
