Memory card format problem
Hello,
hello
2 answers Last reply
More about memory card format problem
  1. what is your problem , please be specific ? have you tried formatting with command or disk management ? and if it is a write protected UBS drive .. you can download tools like : HP UBS storage format tool , or you can edit your registry ...in the roots
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies. Change the value for the key "WriteProtect" to 0
  2. forgot to mention for disabling "write protected" in Windows 7 ..
    Open a command prompt window (start –> run –> type in the run window cmd
    In the command prompt type "diskpart" Type "list volume" this will list all the drives on your computer and give them all volume numbers.
    Next you want diskpart to set focus on the write protected drive "select volume #" which ever volume is the disk in question.
    Now enter "attributes disk clear readonly" and then type "attributes volume clear readonly"
    Check the drive in question, you should now be able to access the disk with full permissions
Hard Drives Memory Card Format Storage
