Vertical Hold on CRT Monitor
Hello,
How do i fix the vertical hold on the crt monitor vx74?
3 answers Last reply
More about vertical hold monitor
  1. Look for a knob, possible on the back you might be able to adjust it. If not there might be a pop open panel on the front with buttons to let you adjust the settings on the monitor. If you dont have either of those, whack it on the top and side, it can fix older tube based systems.
  2. Thank you hunter315. I guess I will just have to hit it! There are no reset buttons and panels, just the normal screen option settings.
  3. The knob could be located in back of the monitor.
Nvidia CRT Monitors Graphics
