Hey all.
i recently just bought a gigabyte HD 5830. it's been running really well, but i've heard that it also overclocks quite well--unfortunately, i have achieved very poor results.
i've done the overclock so far using the catalyst control centre and the core clock will not go above 850MHz. i set it to 860 and run the CCC test and i always fail it. this seems unlike, as i've heard everybody else getting overclocks in excess of 900MHz EASSSY. furthermore, at said clocks it idles at 36 celsius and loads from 55-60. (i've enver seen it past 58)
i do not think it is a system or power limitation (specs below), but did i just get unlucky and get a card that is that bad?
any advice on other programs i can use to OC with ATI cards as well?
system:
Gigabyte GA-MA78GM-US2H
Athlon II X4 620 @ 3.2GHz, OCZ Gladiator 92mm cooler.
4GB Corsair DDR2 RAM
Hitachi 500GB HDD
OCZ 600W ModXStream PSU
Gigabyte 5830
system:
Hitachi 500GB HDD
Gigabyte 5830
