Well Hello guys, it's been a while since I have been away from this forum and I was wondering if you guys could help me out.
Well my problem may seem a bit odd at the most but hope you can understand. Well as of October 2012 - I do have a new PC with all the new requirements that I could ever have. But the thing is I still have my old PC and my cousin wanted to use it - I very much would love to hand it over to him but there's one problem that I am facing with that system and I am sure my buddies here could help me solve this problem or at the least find a solution with which I can fix this thing.
So the Problem is : My old computer is running on Windows XP Service Pack 3. (I never thought of upgrading it as I was planning to buy a new PC plus I loved Windows XP too much to just change it.) I have 2 HDD (Mechanical Hard Drive) - One is of 256 GB HDD and the other is 2 TB HDD. The 2 TB HDD was added later on to the old PC. All the other parts are just running fine. So the problem is with the 256 GB HDD. My 256 GB HDD is divided into 4 Partitions, Local Disk : C,D,E & F. My Windows XP is installed in Local Disk C which has a total size of - 24.5 GB. and the problem is that this particular partition which has the Windows installed - The Space is getting down and getting lower everyday. Yesterday it was 19.5 GB and Today it is 17.8 GB - I think it is happening because the 256 GB HDD is very old - almost 5-6 years old and I guess it's dying, Am I right.?
If So than I have an idea - but I don't know if it will work and I need some help on this from you guys - What I plan on doing is that I am thinking of doing a dual Operating System on the PC. I will leave the Windows XP as it is, and I am thinking of installing Windows 7 on the 2 TB HDD (I know it will be slow since it's not an SSD, I don't care - I don't want to spend extra money on this PC, I just want it to get running and send it off to my cousin) So what I want to know is what are the steps as to how I should Install Windows 7 on the 2 TB HDD when I already have Windows XP on the 256 GB HDD. And will installing Windows 7 on the 2 TB HDD affect the files which are present on the 256 GB HDD (Windows XP) and I have a few files present in the 2 TB HDD, will I need to format the complete 2 TB HDD and than do a clean installation of Windows 7 on the 2 TB HDD or can I make a Separate Clean Partition of around 200 GB and Install Windows 7 on there. I forgot to Mention my 2 TB HDD is also partitioned into 2 Drives - Local Disk : J and K.
If you need any more pointers to help me solve the problem, just ask me and I will tell you all about the computer.
