Hi ,
I need help choosing a Motherboard for i5-2500K CPU. I was looking at ASUS, Gigabyte, ASrock and MSI motherboards. Some of my concerns/requirements are:
1) I use both windows and Linux, windows for gaming and Linux for programming/work. So the Mobo should be completely compatible with linux as well.
ASrock has etron Usb 3.0 chipsets, i heard they do not work with linux.
Gigabyte has Renesas D720200 chipsets, the z68 ones have etron chipsets.
Asus uses both nec and ASMedia chipsets.
Msi uses NEC chipsets.
2) P67 vs Z68 - which is better for OC?
3) I have seen that a lot of ASUS p67 users have had problems with the board eg. reboot loops. Are there any known bugs for the other boards? are there any fixes out for these bugs. How is the customer service by these companies?
4) Overclocking - I read that higher VRM phases give better OC stability, some of the MSI mobos have only 4-6 phases are they any good for OC?
5) Finally price, I am looking for some thing in the $150 - $200 range.
All suggestions are welcome, Thanks
