Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Memory > System Boots 1 Stick RAM, Will NOT Boot with 2 sticks Ram
Forum Motherboards & Memory : Memory System Boots 1 Stick RAM, Will NOT Boot with 2 sticks Ram
Just got new parts. Putting comp together. System cycles on 3 seconds, off 3 seconds, repeat with DDR3 Ram in Slots 1 and 3. Either Stick of ram in slot 1 can boot system. Anyone have any ideas what my problem could be?
The Ram is 1866 and the board only supports 1600(OC)/2133(OC), could that be a problem? I thought it would just downclock 2 sticks to 1600? When I boot with 1 stick it says its running at 1600. with voltage at 1.47. Please help.
RAM:
G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
http://www.newegg.com/Product/Prod [...] 6%20sniper
MOBO:
MSI P67A-GD65 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] -_-Product
Message edited by matth87 on 06-05-2011 at 12:25:17 AM
Reply to matth87
If by slot 1 you mean the one closest to the CPU, you have the RAM in the wrong slots. Slot 1 should only be used if you have one stick of RAM or if you have four sticks of RAM.
Here's the way it should be with two sticks:
Slot1 (closest to CPU): Empty
Slot 2: RAM
Slot 3: Empty
Slot 4: RAM
------------------------------ Jack-Booted Thug Spreading Intel Sandy Bridge Propaganda
Member of the Official TH Water Cooling Club
|2500K CPU|12GB RAM|570 GPU|96GB SSD|1TB HDD|
Reply to Leaps-from-Shadows
There are 2086 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Memory for GIGABYTE GA-G41MT-S2P
By fantastik250, 2 hours ago:
Take a look at this and see if you like it. http://www.newegg.com/Product/Prod [...]...
Best offers
Top experts
