Will case fans fit my PC?
Last response: in Components
you don't need a side panel fan, especially a 80mm one.
the rear exhaust looks like its a 92mm/120mm so I doubt the 80mm will fit. your current cpu is a 80mm so it looks to be smaller then the exhaust port (hard to tell from your pics)
How about now can you now?
Uploaded with ImageShack.us
Related ressources
ct1615 said:
take a look at your CPU fan. if it is smaller then your exhaust port you, have a 92/120mm port. if it can fit its a 80/92mm. either way a 92mm fan will fit.
Ok it came today look like it does fit now only problem is how am I going put the fan mounting screws in? It takes a lot Effort to put the screws let a alone one screw.
Ask the community
