G
Guest
Guest
Hellow every body
i am from israel so my english is prety bad so if there are any mistakes just ignore it - Thanx
ןI gonna buy this GPU :
Nvidia - Palit GTS 250 1GB DDR3
will it work on my computer ? and will it be felt (i ask if i can feel the grapich change at games )
its my computer:
http://www.siz.co.il/my.php?i=4mo4go4wimng.png
and more information from EVEREST program and from the produceres sites
PSU:
Thermaltake Tr2 standart series
Watt P/N +12V PCI-Express SATA PFC Fan Certification Efficiency Noise
430 W0070RUC 18A 1 2 N/A 80 MM N/A 65% + 19 dBA
(copied from thermaltake's site)
CPU: QuadCore Intel Core 2 Quad Q9400
- THE INFORMATION ARE COPIED FROM THE PROGRAM EVERST ! -
CPU Properties
CPU Type QuadCore Intel Core 2 Quad Q9400, 2666 MHz (8 x 333)
CPU Alias Yorkfield-3M
CPU Stepping E0
Instruction Set x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1
Original Clock 2667 MHz
Min / Max CPU Multiplier 6x / 8x
Engineering Sample No
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 2x 3 MB (On-Die, ECC, ASC, Full-Speed)
Multi CPU
CPU #1 Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz, 2671 MHz
CPU #2 Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz, 2671 MHz
CPU #3 Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz, 2671 MHz
CPU #4 Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz, 2671 MHz
CPU Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/products/processor
CPU Utilization
CPU #1 / Core #1 0 %
CPU #1 / Core #2 28 %
CPU #1 / Core #3 14 %
CPU #1 / Core #4 0 %
GPU: Nvidia 8800GT 512 MB
Field Value
Graphics Processor Properties
Video Adapter BFG GeForce 8800 GT
BIOS Version 62.92.1F.00
GPU Code Name G92GT
PCI Device 10DE-0611 / 19F1-06DC (Rev A2)
Transistors 754 million
Process Technology 65 nm
Die Size 315 mm2
Bus Type PCI Express 2.0 x16 @ x16
Memory Size 512 MB
GPU Clock (Geometric Domain) 626 MHz (original: 625 MHz)
GPU Clock (Shader Domain) 1566 MHz (original: 1566 MHz)
RAMDAC Clock 400 MHz
Pixel Pipelines 16
TMU Per Pipeline 1
Unified Shaders 112 (v4.0)
DirectX Hardware Support DirectX v10
Pixel Fillrate 10016 MPixel/s
Texel Fillrate 35056 MTexel/s
Memory Bus Properties
Bus Type GDDR3
Bus Width 256-bit
Real Clock 900 MHz (DDR) (original: 900 MHz)
Effective Clock 1800 MHz
Bandwidth 56.3 GB/s
nVIDIA ForceWare Clocks
2D/3D GPU: 625 MHz, Shader: 1566 MHz, Memory: 900 MHz
Graphics Processor Manufacturer
Company Name NVIDIA Corporation
Product Information http://www.nvidia.com/page/products.html
Driver Download http://www.nvidia.com/content/drivers/drivers.asp
Driver Update http://driveragent.com?ref=59
MOTHER BOARD : Asus p5k-e
Field Value
Motherboard Properties
Motherboard ID 65-1305-000001-00101111-061909-Bearlake$A0812001_BIOS DATE: 06/19/09 14:57:25 VER: 08.00.12
Motherboard Name Asus P5K-E
Front Side Bus Properties
Bus Type Intel AGTL+
Bus Width 64-bit
Real Clock 333 MHz (QDR)
Effective Clock 1333 MHz
Bandwidth 10664 MB/s
Bus Type Dual DDR2 SDRAM
Bus Width 128-bit
DRAM:FSB Ratio 12:10
Real Clock 400 MHz (DDR)
Effective Clock 800 MHz
Bandwidth 12797 MB/s
Chipset Bus Properties
Bus Type Intel Direct Media Interface
Motherboard Physical Info
CPU Sockets/Slots 1 LGA775
Expansion Slots 3 PCI, 2 PCI-E x1, 2 PCI-E x16
RAM Slots 4 DDR2 DIMM
Integrated Devices Audio, Gigabit LAN, IEEE-1394
Form Factor ATX
Motherboard Size 240 mm x 300 mm
Motherboard Chipset P35
Extra Features Asus Intelligence, JumperFree, Q-Fan 2, Stepless Freq Selection, SATA-II, RAID
Motherboard Manufacturer
Company Name ASUSTeK Computer Inc.
Product Information http://www.asus.com/products.aspx?l1=3
BIOS Download http://support.asus.com/download/download.aspx?SLanguage=en-us
Memory : i have four card with the same type
DIMM1: Kingston (1 GB DDR2-800 DDR2 SDRAM)
DIMM2: Kingston (1 GB DDR2-800 DDR2 SDRAM)
DIMM3: Kingston (1 GB DDR2-800 DDR2 SDRAM)
DIMM4: Kingston (1 GB DDR2-800 DDR2 SDRAM)
Field Value
Memory Module Properties
Module Name Kingston
Manufacture Date Week 24 / 2008
Module Size 1 GB (2 ranks, 4 banks)
Module Type Unbuffered DIMM
Memory Type DDR2 SDRAM
Memory Speed DDR2-800 (400 MHz)
Module Width 64 bit
Module Voltage SSTL 1.8
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings
@ 400 MHz 6-6-6-18 (CL-RCD-RP-RAS) / 24-42-3-6-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 333 MHz 5-5-5-15 (CL-RCD-RP-RAS) / 20-35-3-5-3-3 (RC-RFC-RRD-WR-WTR-RTP)
@ 266 MHz 4-4-4-12 (CL-RCD-RP-RAS) / 16-28-2-4-2-2 (RC-RFC-RRD-WR-WTR-RTP)
Memory Module Manufacturer
Company Name Kingston Technology Company, Inc.
Product Information http://www.kingston.com/products/default.asp
Hard disks :
NUMBER 1:
ATA Device Properties
Model ID Hitachi HDT721032SLA360
Revision ST2OA31B
World Wide Name 5-000CCA-346DC1F94
Device Type SATA-II
Parameters 620181 cylinders, 16 heads, 63 sectors per track, 512 bytes per sector
LBA Sectors 625142448
Buffer 15001 KB (Dual Ported, Read Ahead)
Multiple Sectors 16
ECC Bytes 56
Unformatted Capacity 305245 MB
ATA Device Features
48-bit LBA Supported
Advanced Power Management Supported, Disabled
Automatic Acoustic Management Supported, Enabled
Device Configuration Overlay Supported
DMA Setup Auto-Activate Supported, Disabled
General Purpose Logging Supported
Host Protected Area Supported, Enabled
In-Order Data Delivery Supported, Disabled
Native Command Queuing Supported
Phy Event Counters Supported
Power Management Supported, Enabled
Power-Up In Standby Supported, Disabled
Read Look-Ahead Supported, Enabled
Release Interrupt Not Supported
Security Mode Supported, Disabled
SMART Supported, Enabled
SMART Error Logging Supported
SMART Self-Test Supported
Software Settings Preservation Supported, Enabled
Streaming Supported
Tagged Command Queuing Not Supported
Write Cache Supported, Enabled
ATA Device Physical Info
Manufacturer Hitachi
Hard Disk Family Deskstar 7K1000.B
Form Factor 3.5"
Formatted Capacity 320 GB
Physical Dimensions 147 x 101.6 x 26.1 mm
Max. Weight 400 g
Average Rotational Latency 4.17 ms
Rotational Speed 7200 RPM
Max. Internal Data Rate 1388 Mbit/s
Interface SATA-II
Buffer-to-Host Data Rate 300 MB/s
Buffer Size 16 MB
ATA Device Manufacturer
Company Name Hitachi Global Storage Technologies
Product Information http://www.hgst.com/products
NUMBER 2-
Model ID WDC WD1600JD-00HBB0
Revision 08.02D08
Device Type SATA
Parameters 310101 cylinders, 16 heads, 63 sectors per track, 600 bytes per sector
LBA Sectors 312581808
Buffer 8 MB (Dual Ported, Read Ahead)
Multiple Sectors 16
ECC Bytes 74
Unformatted Capacity 178861 MB
ATA Device Features
Advanced Power Management Not Supported
DMA Setup Auto-Activate Not Supported
General Purpose Logging Not Supported
In-Order Data Delivery Not Supported
Native Command Queuing Not Supported
Phy Event Counters Not Supported
Software Settings Preservation Not Supported
Streaming Not Supported
Company Name Western Digital Corporation
Product Information http://www.westerndigital.com/en/products
Fans:
CPU COOLER - Thermaltake V1
* Supports All CPUs up to 130W TDP
Heatsink Dimension 147 (L) x 92 (W) x 143 (H) mm
5.8 (L) x 3.7 (W) x 5.3 (H) inch
Heatsink Material Copper Base & Copper Fin
Heatpipe Copper Tube 6 mm x 4 pcs.
Fan Dimension 110 x 25 mm
Fan Speed 1300 ~ 2000 RPM
Bearing Type
Noise Level 16 dBA ~ 24 dBA
Max. Air Flow 86.5 CFM
Max. Air Pressure 2.22mm H2O
LED Fan Blue Color
Power Connector 3-pin
Rated Voltage
Started Voltage 7V
Rated Current 12V
Power Input 3W
MTBF 50,000 Hours
Weight 637g
GPU COOLER:
arctic cooling - accelero TwinTurbo
• Unmatched cooling performance – up to 120W
• Efficient heat transfer via 4 heatpipes and 30 fins
• Two ultra quiet 80mm fans with low noise impeller
• Patented fan holder eliminates the buzzing sound
• RAM and voltage regulator cooling
• SLi and Crossfire compatible
• Pre-applied MX-2
• Lightweight, transport safe
• 6 year warranty
if more information is needed abute this cooler go to this link:
http://www.arctic-cooling.com/catalog/product_info.php?cPath=2_&mID=101
and one more fan - gigabyte fan MODEL F121225SL
Fan 12cm (120 x 25mm), 400 ~ 950rpm, 17.75 ~ 42.15 CFM, 15 ~ 18dBA, power connector 3-pin (with sign of rotation), speed control by temperature.
Features
Part Number: F121225SL Part Number: F121225SL
Cor: Preta e azul Color: Black and blue
Modelo de 12cm Model 12cm
Conector de energia de 3 pinos (com sinal de rotação) Power Connector 3-pin (with sign of rotation)
Controle de velocidade por temperatura (31 ~ 60ºC) e sensor com cabo Speed control by temperature (31 ~ 60 º C) and sensor cable
Especificações Specifications
- Dimensões: - Dimensions:
120 x 25mm 120 x 25mm
- Velocidade: - Speed:
@ 60ºC: 950rpm @ 60 º C: 950rpm
@ 31ºC: 400rpm @ 31 ° C: 400rpm
- Fluxo de ar: - Airflow:
@ 60ºC: 42,15CFM @ 60 º C: 42.15 CFM
@ 31ºC: 17,75CFM @ 31 º C: 17.75 CFM
- Tensão: - Voltage:
+12V (8 ~ 13,2V) +12 V (8 ~ 13.2 V)
- Corrente: - Current:
@ 60ºC: 0,2A @ 60 ° C: 0.2 A
@ 31ºC: 0,08A @ 31 ° C: 0,08 A
- Potência: - Power:
@ 60ºC: 2,4W @ 60 ° C: 2.4 W
@ 31ºC: 0,96W @ 31 º C: 0.96 W
- Rolamento: - Bearing:
Enter Bearing Enter Bearing
- Ruído: - Noise:
@ 60ºC: 18dBA @ 60 º C: 18dBA
@ 31ºC: 15dBA @ 31 ° C: 15dBA
- Pressão estática: - Static pressure:
@ 60ºC: 0,57 mm-H2O @ 60 º C EUR0.57 mm-H2O
@ 31ºC: 0,1 mm-H2O @ 31 ° C: 0.1 mm-H2O
- Conector de energia: - Power Connector:
3 pinos (com sinal de rotação) 3-pin (with sign of rotation)
- Comprimento do cabo: - Cable length:
Energia: ± 50cm Energy: ± 50cm
Sensor de temperatura: ± 30cm Temperature Sensor: ± 30cm
THE END !! its my fierst time here so i psosted any information i got
plase help i realy need help here (at israel no body answered me !)
its my computer:
PSU:
CPU Properties
CPU Stepping E0
Multi CPU
CPU Manufacturer
CPU Utilization
Field Value
GPU Code Name G92GT
Die Size 315 mm2
Memory Size 512 MB
Pixel Pipelines 16
TMU Per Pipeline 1
Bus Type GDDR3
Bus Width 256-bit
Bandwidth 56.3 GB/s
Field Value
Bus Width 64-bit
Bus Width 128-bit
Form Factor ATX
Field Value
Module Width 64 bit
Memory Timings
Hard disks :
NUMBER 1:
Revision ST2OA31B
Device Type SATA-II
Multiple Sectors 16
ECC Bytes 56
ATA Device Features
Streaming Supported
Form Factor 3.5"
Max. Weight 400 g
Interface SATA-II
Buffer Size 16 MB
NUMBER 2-
Revision 08.02D08
Device Type SATA
Multiple Sectors 16
ECC Bytes 74
ATA Device Features
Fans:
Bearing Type
LED Fan Blue Color
Rated Voltage
Started Voltage 7V
Rated Current 12V
Power Input 3W
MTBF 50,000 Hours
Weight 637g
GPU COOLER:
• Pre-applied MX-2
• 6 year warranty
Features
- Ruído: - Noise:
