Ok, so I'm a novice at computer building, and I have a crucial question. How the heck am I supposed to pick a power supply? Here are my prospective specs for a future build:
ASUS M4A78LT-M LE (http://www.newegg.com/Product/Product.aspx?Item=N82E16813131619)
AMD Athlon II x4 630 (http://www.newegg.com/Product/Product.aspx?Item=N82E16819103704&cm_re=AMD_Athlon_II_X4_630-_-19-103-704-_-Product)
G. Skill Eco Series 4GB (2 x 2GB) DIMM DDR3 SDRAM 1600 (http://www.newegg.com/Product/Product.aspx?Item=N82E16820231321&nm_mc=AFC- C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=)
Lite-On Lightscribe 24x SATA DVD+/-RW Dual Layer (http://www.amazon.com/Lite-LightScribe-Layer-Drive-IHAS424-98/dp/B002SIMPXM/ref=wl_it_dp_o?ie=UTF8&coliid=I1X6E276W3QBGH&colid=314JAQ581OAFP)
Samsung Spinpoint 1TB (http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185&cm_re=Samsung_Spinpoint_F3-_-22-152-185-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=)
So.....which power supply is going to give me what I need?
P.S. I do hope to add a tv tuner expansion card if I don't get it with my monitor.
