Hi guys ....
My first post here so please have some patience.
I just bought a new rig with the following components:
Mobo: Asus Crosshair iV Extreme
CPU: Amd x6 Black Edition
GPU: Gainward 580gtx Phantom
Mem: Kingston DDR3 16GB pack (4x4GB) 1600Mhz
PSU: Fractal Design Newton R2 800W
Case: Fractal Design Define XL Pearl Black
CPU Fan: Noctua NH-D14
Ive built system from the ground before without any major issues, but this time I can get the grip of what the problem is and it is hard to return parts if your not sure what is causing the problem.
Symtom:
All stuff fitted as suggested by manuals for the products. CPU power cable etc. is inserted on the mobo. When I give the PSU power the Mobo lights up as it should, but no reaction, neigther on the case powerswitch, nor the Start or GO button on the mobo. Tried picking out mem, changed GPU, tried other PSU, removed CPU, refitted CPU ... same thing.
I dont got any spare AMD cpu to try out, and I dont got any other system to try the CPU in. So, either the CPU, or the Mobo it feels like. I need to get my hands on a systemspeaker as my case is missing speaker from what I can see.
It seems then I search around the need quite a few have had this problem with Asus mobos but I have not been able to trace down a solution.
So, please guys, any ideas?
And please excuse my bad english :-(
//Roger
Symtom:
//Roger
