Solved
Geforce MX 4000 graphic card installation problems
Hello,
Installed Geforce MX 4000 in Dell Dimension 4600 and got to desktop but no start button then rebooted and got tool bar and no icons. Dell Dimension has integrated video but would like to get this Nvida card to work. Have 1 gig memory installed with 160 gig hard drive. thanks
4 answers Last reply Best Answer
More about geforce 4000 graphic card installation problems
  1. Best answer
    Did you disable the integrated in device manager before installing the card?
  2. No I did not disable integrated before I installed the card. Thanks I'll try that next.
  3. Thank you. Works fine now.
  4. Best answer selected by merlinfive.
Graphics Cards Dimension Geforce Dell Graphics
