My pc has been working perfectly for the past year or so i've had it, but recently i've been having some serious issues. I noticed about a week ago that some of my games that would usually run a constant 60fps were dropping below 20fps. I could restart my computer and the problems seemed to be fixed.
After a while visual artifacts started to show up followed by crashing. I noticed that is only affected 3d applications but eventually i started recieving the same problem when i watched any videos. I installed the latest drivers from the nvidia site but it didn't seem to do anything. Now I'm getting artifacts (sometimes) on the boot menu and it is difficult even to get windows to start. Attempting to run any game or video usually results in the screen freezing and many colored dots appearing onscreen along with some discoloration.
I'm guessing that the problem is with my video card. It was factory superclocked but i never did any major overclocking with it. I don't think heat is an issue either. When I tested out some games with EVGA precision the temp never get any higher than 70 C. I check my voltages through my mobo utility and they seemed right. Are the problems from my 280 or could it be from something else?
Specs:
EVGA X58 SLI LE
Intel i7 2.66
EVGA GTX 280 SSC
Corsair TX750W
Corsair 4GB DDR3 RAM
Specs:
EVGA X58 SLI LE
Intel i7 2.66
EVGA GTX 280 SSC
Corsair TX750W
