Using 3-pin Y-Splitters to Control 2 Fans on One Header
- Need to control 6 3-pin fans with 2 fan headers using Speedfan Forum
- Can i use a pwm splitter to control 3pin case fans woth the cpu 4pin header?? Forum
- Solved2x 3-pin fans in 1 system fan header? Forum
- SolvedWill using a 3-pin splitter still control fans? Forum
- SolvedCan 3-pin fan headers control 3-pin fans? Forum
- 3x 3pin case fans controlled by 1 PWM Mobo header? Forum
- SolvedUse a 2-pin ATX fan on a 3-pin mobo PWM controller? Forum
- SolvedControl two different fans with one fan header w/ Y splitter Forum
- Help connecting 2x 3pin fans to 4pin mobo header Forum
- 3-pin 3-speed Noctua NF-S12B FLX fan, 4-pin motherboard headers... Speed control? Forum
- SolvedConnecting 2 fans to mobo using 1 header? Forum
- 2 fans on one 3pin (mobo) Forum
- 2 Fans off one header Forum
- 2 fans in one mobo header Forum
- Should I use my motherboards cpu fan header or my fan controllers for push pull cpu liquid cooler. Forum
- Can I power 2 fans with one MB header? Forum
- Using a Fan Controller Without a computer that has a Fan Header Plug... Forum
- SolvedWill my motherboard sys fan headers provide enough power to power 4 fans altogether on 2 of the headers using power splitter? Forum
- Using 2 bluetooth controllers with only one usb adapter? Forum
- More resources
Read discussions in other Motherboards categories
