Gigabyte ga-x58a-ud7 rev 2 0 power problems
Just assembled a system using the UD7. Upon initial power-up everything was fine. It went through post to ask for a boot disk. I restarted, entered the BIOS, changed the date and time and enable legacy keyboard and mouse. Saved and turned off the machine.
I then restarted with the windows cd in the player. It started copying files and then abruptly turned off. It now turns itself off before it can post.
Any advice would be appreciated.
Thanks,
Eric
1 answer Last reply
More about gigabyte x58a power problems
  1. what are your specs? PSU, MEM, MOBO, GPU, etc...
Homebuilt Systems
