New AMD Phenom II 955 Build, help?
Last response: in Systems
Hello, I plan on building a new AMD rig thats descent for gaming and movies. Ive been doing quite a bit of research and I do plan on overclocking. I pretty much want a PC that will last me for the next couple years. I do plan on either crossfire or sli later on, but not as of now. So far I've got a couple of things on my list, but I need some opinions or recommendations. I am also trying to build this pc pretty much with the idea of "best bang for the buck".
Mobo's
GIGABYTE GA-890FXA-UD5 159.99
GIGABYTE GA-MA790FXT-UD5P
GIGABYTE GA-MA790X-UD4P 109.99
ASUS M4A79T Deluxe 169.99
ASUS Crosshair III Formula 145.15
MSI 790FX-GD70 AM3 AMD 167.99
RAM
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 97.99
OCZ AMD Black Edition 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 100.99
PSU
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 109.99
CPU Cooler
Zalman 9900 Heat Sink 65.99
ZALMAN CNPS 9700 NT 110mm 2 Ball Ultra Quiet CPU Cooler 59.99
CORSAIR Cooling Hydro Series CWCH50 79.99
GPU
SAPPHIRE Vapor-x Radeon Hd 4890 1GB 256-bit GDDR5 156.99
If anyone has recommendations, please let me know and explain. Thank you
More about : amd phenom 955 build
Here is a build that you can check
X4 955 + Corsair 4GB
http://www.newegg.com/Product/ComboDealDetails.aspx?Ite...
ASUS 890GX + ASUS HD 5770(Though not as powerful as the HD 4890, but is DirectX 11) - But if DirectX 11 doesnt matter, then get that HD 4890...
CASE + PSU
CPU Cooler - Cheaper and as good if not better...
U mentioned best bang for buck then IMO ditch any ideas of CF/SLI Just Cause 2 and Metro 2033 just made decent GPUs of recent times look rubbish so buy and upgrade via a single GPU solution for gaming needs/requirement of tommorrow
$649AR
you might be able to save a little more with an AMD770 chipset, which sacrifies only SATA 3.0 (6GB) for SATA II (3GB), which doesn't matter for anything but a few solid state drives
Ask the community
