G
Guest
Guest
Hi. I've got a problem with my graphics card which I'm hoping there's a simple solution for.
During a recent run of FurMark the temperature of my card reached about 85°C with the card's fan spinning at around 2200rpm to keep it cool. The fan's then suddenly spun down to 940rpm and refused to increase in speed even as the temperature rose to 90C. That's when I quickly shut down the benchmark.
Using CCC I've tried to increase the fan speed but no matter what I manually set the speed at the fan remains at a slow 940rpm. However, it does shoot to 4000-ish rpm when I set it to 100%, something which I don't plan to do.
In GPU-Z (0.4.3) it shows that the fan speed doesn't increase at all, even if the percentage changes.
Other stats of my PC:
OS: Windows 7 64-bit
Driver: Catalyst 10.4
CPU: Core i7 920 @ stock
GPU: HD5850 (Sapphire)
PSU: Thermaltake Toughpower QFan 750W
