Closed
Motherboard lights up but does not turn on or post
Hello,
I have a problem that strikes me as rather odd....I have an ASUS P7P55D-E motherboard. The computer was working perfectly fine and then did not turn on when I moved it to another room. I didn't drop it or anything. Well, I've tested the RAM, power supply, and graphics card in other computers and they all work properly. The lights on the motherboard for BOOT_LED light up when hooked up to the power supply but turning it on does nothing. I have tried changing cases and it still doesn't work.
What is the problem here?
5 answers Last reply
More about motherboard lights turn post
  1. Do you see any hard drive activity lights? Check your monitor connection and make sure it is plugged in properly. Check all your connections on the back.
  2. No hard drive activity lights, no power light, monitor and everything is plugged in fine. None of the fans even spin up. Basically, there are lights on the motherboard that are lit up to indicate it is connected to a power supply, but it won't turn on at all.
  3. That may just be the +5VSB. Reseat your power connectors. Check on/under your mobo for anything like a dropped screw. Make sure you only have standoffs in the right places (where there are mobo holes for them). Check the power switch and its wires.
  4. If the system worked before you moved it, but doesn't work afterwards, check all of the cabling.
    If that doesn't help:
    Work systematically through our standard checklist and troubleshooting thread:
    http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems
    I mean work through, not just read over it. We spent a lot of time on this. It should find most of the problems.
    If not, continue.
    The following is an expansion of my troubleshooting tips in the breadboarding link in the "Cannot boot" thread.
    I have tested the following beep patterns on Gigabyte, eVGA, and ECS motherboards. Other BIOS' may be different, but they all use a single short beep for a successful POST.
    Breadboard - that will help isolate any kind of case problem you might have.
    http://www.tomshardware.com/forum/262730-31-breadboarding
    Breadboard with just motherboard, CPU & HSF, case speaker, and PSU.
    Make sure you plug the CPU power cable in. The system will not boot without it.
    I always breadboard a new build. It takes only a few minutes, and you know you are putting good parts in the case once you are finished.
    You can turn on the PC by momentarily shorting the two pins that the case power switch goes to. You should hear a series of long, single beeps indicating memory problems. Silence indicates a problem with (in most likely order) the PSU, motherboard, or CPU. Remember, at this time, you do not have a graphics card installed so the load on your PSU will be reduced.
    If no beeps:
    Running fans and drives and motherboard LED's do not necessarily indicate a good PSU. In the absence of a single short beep, they also do not indicate that the system is booting.
    At this point, you can sort of check the PSU. Try to borrow a known good PSU of around 550 - 600 watts. That will power just about any system with a single GPU. If you cannot do that, use a DMM to measure the voltages. Measure between the colored wires and either chassis ground or the black wires. Yellow wires should be 12 volts. Red wires: +5 volts, orange wires: +3.3 volts, blue wire : -12 volts, violet wire: 5 volts always on. Tolerances are +/- 5% except for the -12 volts which is +/- 10%.
    The gray wire is really important. It should go from 0 to +5 volts when you turn the PSU on with the case switch. CPU needs this signal to boot.
    You can turn on the PSU by completely disconnecting the PSU and using a paperclip or jumper wire to short the green wire to one of the neighboring black wires.
    http://www.youtube.com/watch?v=5FWXgQSokF4&feature=youtube_gdata
    A way that might be easier is to use the main power plug. Working from the back of the plug where the wires come out, use a bare paperclip to short between the green wire and one of the neighboring black wires. That will do the same thing with an installed PSU. It is also an easy way to bypass a questionable case power switch.
    This checks the PSU under no load conditions, so it is not completely reliable. But if it can not pass this, it is dead. Then repeat the checks with the PSU plugged into the computer to put a load on the PSU.
    If the system beeps:
    If it looks like the PSU is good, install a memory stick. Boot. Beep pattern should change to one long and several short beeps indicating a missing graphics card.
    Silence, long single beeps, or series of short beeps indicate a problem with the memory. If you get short beeps verify that the memory is in the appropriate motherboard slots.
    Insert the video card and connect any necessary PCIe power connectors. Boot. At this point, the system should POST successfully (a single short beep). Notice that you do not need keyboard, mouse, monitor, or drives to successfully POST.
    At this point, if the system doesn't work, it's either the video card or an inadequate PSU. Or rarely - the motherboard's PCIe interface.
    Now start connecting the rest of the devices starting with the monitor, then keyboard and mouse, then the rest of the devices, testing after each step. It's possible that you can pass the POST with a defective video card. The POST routines can only check the video interface. It cannot check the internal parts of the video card.
  5. Well, the motherboard does not turn on at all. By the title of this thread I meant that it doesn't turn on, let alone POST. After reading the trouble shooting guide I think that maybe the motherboard is shorted somewhere, because the BOOT_DEVICE_LED is lit up but nothing is turning on. I've done the fan test on the PSU. And this computer was working before fine so I know everything is fine with the processor placement. And I've been running the graphics card in another computer now for a day without issue.
Asus Light Power Supplies Motherboards
