Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > What power does my psu really supply
Forum CPU & Components : Power Supplies, Cases & Mods What power does my psu really supply
Hi
I have a huntkey 550w greenpower, does it really supply 550w or less, I want to add a second Radeon 5770, but that will depend on how much power I have to work with, the psu is rated at 80+ Bronze. Please advise
Current Specs: Amd phenom2 965, 2*2GB Kingston 1333, Radeon 5770 1gb ddr5, 5oogb 1tb and 1.5tb seagate HDD's, std 22* dvd writer, raidmax Quantum case,
Also how do I tell if my processer is c3 stepping or not ie it draws 130w or 140w
Thank you for your support and time
Reply to NightDrift
I would consider getting a quality PSU before putting in another HD5770.
A PSU only puts out the power that the components need.
Reply to rolli59
any advice on the processor question?
Reply to NightDrift
- 0 +
Download and install a program called CPU-Z. It will peek inside your CPU and tell you what your core stepping is.
Reply to jsc
Here are the official ATI power supply requirements for the ATI Radeon HD 5770 and 5750 video cards:
450 Watt or greater power supply with one 75 watt, 6-pin PCI Express® power connector recommended
600 Watt or greater power supply with two 75 watt, 6-pin PCI Express® power connectors for ATI CrossFireX™ technology in dual mode
The recommendations are for an entire pc system.
Corsair and Seasonic are two brands that have a reputation for high quality power supplies that consistently earn high marks in technical reviews. They are reliable, stable, and come with a 5 year warranty. Some of the newer models come with a 7 year warranty (in the USA).
Reply to JohnnyLucky
There are 1958 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Case with filters. Recommendations?
By al360ex, 6 hours ago:
Then I'd go with one of these cases. If you choose the HAF 932 Advanced Edition, you...
Best offers
Top experts
