Hi Everyone,
I am looking into finally upgrading my 5 year old Dell Dimension 8400 with a gaming rig to get me through, SC2, Diablo 3, and WoW (for now). I do want to future-proof the machine for at least 2-3 years before needing an upgrade.
My budget is around the $1500 range, plus or minus $200 depending on what the stretch is for.
I am in no immediate rush, so waiting a month or two here or there is fine.
I plan on getting a new monitor, but I do have a 20in Dell LCD which I can work with for some time. With a new monitor, I would be expecting to push the resolution to the 1920x1200 range,
I am not opposed to getting a system from iBuyPower or CyberPower, though I would also be willing to try building my own system (using parts from newegg or otherwise).
I do not plan to overclock though SLI or crossfire in the future would be cool.
Here is a base build that I used CyberPower to put together, though I would be willing to mix/match based on input from experts:
CD:24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
CAS:* In-Win Ironclad Full Tower Gaming Case w/ 220MM Side Panel Fan (Black Color)
CS_FAN: Default case fans
CPU:Intel® Core™ i7-975X Extreme Edition 3.2 GHz 8M Intel Smart Cache LGA1366
FAN:Asetek 510LC Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA)
HDD:30 GB Kingston 2.5 inch SATA Gaming MLC Solid State Disk (Single Hard Drive)
HDD2:1TB SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Hard Drive)
KEYBOARD:Xtreme Gear (Black Color) Multimedia/Internet USB Keyboard (default)
MOUSE:XtremeGear Optical USB 3 Buttons Gaming Mouse (default)
MONITOR:None (looking for any good suggestions here)
MULTIVIEW:Non-SLI/Non-CrossFireX Mode Supports Multiple Monitors
MEMORY:6GB (2GBx3) DDR3/1333MHz Triple Channel Memory (Corsair Dominator)
MOTHERBOARD:* (3-Way SLI Support) GigaByte GA-X58A-UD3R Intel X58 Chipset SLI/CrossFireX Ultra Durable™3 Triple-Channel DDR3/1600 ATX Mainboard w/ 7.1 Dolby Audio, eSATA, GbLAN, USB3.0, 2 x SATA-III RAID, IEEE1394a, 4 Gen2 PCIe, 2 PCIe X1 & 1 PCI
NETWORK: Onboard Gigabit LAN Network
OS:None - FORMAT HARD DRIVE ONLY [-83]
OVERCLOCK:No Overclocking
POWERSUPPLY:* 950 Watts - Corsair CMPSU-950TX Power Supply - Quad SLI Ready [+94]
SERVICE:STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS:None
TEMP:None
USB:Built-in USB 2.0 Ports
VIDEO:* NVIDIA GeForce GTX 460 1GB 16X PCIe Video Card [-90] (EVGA Powered by NVIDIA [+10])
VIDEO2:None
_PRICE: (+1706)
Let me know what you think - Thanks!
