You really won't see much of an increase. Raid works best with large files, and an OS is made up of a lot of small files. You also run the risk of data loss because as a raid 0 stripe(across 2 drives) if 1 drive fails, you loose the data that was on both drives - even on the one that still works. In my opinion, you're better off just installing them as 2 seperate drives.
